Display All MSDP Information
Use the following procedure to display all the MSDP information.
Switch:#enable Switch:1#show ip msdp show-all ============================================================================ MSDP Show-all - GlobalRouter ============================================================================ # show ip msdp count SA State per Peer Counters, Peer: # SA learned 4.5.35.3: 8 5.7.56.7: 0 AS Num : SA Count 1: 8 # show ip msdp mesh-group No Mesh Group exists # show ip msdp peer MSDP Peer 4.5.35.3, AS 1 Admin Status : enabled Operational Status : enabled Description: Connection status: FSM State: Established, Established Count: 3, Connection source: 4.5.35.5 Uptime (Downtime): 00:00:20 ago, Messages sent/received: 10839/174 Connection and counters cleared 00:00:27 ago SA Filtering: Input (S,G) route-policy: Output (S,G) route-policy: SA In count: 8 SA out Count: 10836 SA-Requests: Input filter: none Sending SA-Requests to peer: disabled SA Request In Count: 0 SA Request out Count: 0 SA Response In Count: 0 SA Response out Count: 0 Peer ttl threshold: 0 SAs learned from this peer: 8, SAs limit: 6144 Peer RPF failure Count: 0 KeepAlive In Count: 166 KeepAlive out count: 3 Encapsulated Data packets In: 8 Encapsulated Data Packets out: 6152 KeepAlive Timer: 60 Peer Hold timer: 75 Connection Retry timer: 30 Encapsulation type: 6 MD5 Authentication: enable Md5 password: %d462277d77 Peer FSM Established Time: 01:20:57 Peer In Message Time: 01:21:00 Remote port: 49156 Local port: 639 Number of connection Attempts: 0 Discontinuity timeout:01:20:50 Too Short MSDP message Rx count: 0 Bad MSDP message Rx count: 0 MSDP Peer 5.7.56.7, AS 2 Admin Status : enabled Operational Status : enabled Description: Connection status: FSM State: Established, Established Count: 2, Connection source: 5.7.56.5 Uptime (Downtime): 00:00:27 ago, Messages sent/received: 4677/77 Connection and counters cleared 00:00:30 ago SA Filtering: Input (S,G) route-policy: Output (S,G) route-policy: SA In count: 0 SA out Count: 4675 SA-Requests: Input filter: none Sending SA-Requests to peer: disabled SA Request In Count: 0 SA Request out Count: 0 SA Response In Count: 0 SA Response out Count: 0 Peer ttl threshold: 0 SAs learned from this peer: 0, SAs limit: 6144 Peer RPF failure Count: 0 KeepAlive In Count: 77 KeepAlive out count: 2 Encapsulated Data packets In: 0 Encapsulated Data Packets out: 8 KeepAlive Timer: 60 Peer Hold timer: 75 Connection Retry timer: 30 Encapsulation type: 6 MD5 Authentication: disable Md5 password: Peer FSM Established Time: 01:20:53 Peer In Message Time: 01:20:53 Remote port: 639 Local port: 49164 Number of connection Attempts: 3 Discontinuity timeout:01:20:50 Too Short MSDP message Rx count: 0 Bad MSDP message Rx count: 0 # show ip msdp sa-cache MSDP Source-Active Foreign Cache - 8 entries (2.10.1.100, 224.5.5.0), RP 3.3.3.3, BGP/AS 1, 00:00:22/00:06:07 (2.10.1.100, 224.5.6.0), RP 3.3.3.3, BGP/AS 1, 00:00:22/00:06:07 (2.10.1.100, 224.5.7.0), RP 3.3.3.3, BGP/AS 1, 00:00:22/00:06:07 (2.10.1.100, 224.5.8.0), RP 3.3.3.3, BGP/AS 1, 00:00:22/00:06:07 (2.11.2.100, 224.6.5.0), RP 3.3.3.3, BGP/AS 1, 00:00:23/00:06:06 (2.11.2.100, 224.6.6.0), RP 3.3.3.3, BGP/AS 1, 00:00:22/00:06:07 (2.11.2.100, 224.6.7.0), RP 3.3.3.3, BGP/AS 1, 00:00:22/00:06:07 (2.11.2.100, 224.6.8.0), RP 3.3.3.3, BGP/AS 1, 00:00:22/00:06:07 # show ip msdp summary MSDP Status Summary MSDP Global Status: enabled cache status: enabled cache-lifetime: 390 seconds cache-count: 8 Originator id: 5.5.5.5 Redistribute: route-policy: SA Limit: 6144 MSDP Peer Status Summary Peer Address AS State Uptime/ Established SA Downtime Count Count 4.5.35.3 1 Established 00:00:27 3 8 5.7.56.7 2 Established 00:00:31 2 0 MSDP Source-Active Local Cache - 12 entries (5.12.5.100, 224.7.5.0), RP 5.5.5.5 (5.12.5.100, 224.7.6.0), RP 5.5.5.5 (5.12.5.100, 224.7.7.0), RP 5.5.5.5 (5.12.5.100, 224.7.8.0), RP 5.5.5.5 (5.13.7.100, 224.8.5.0), RP 5.5.5.5 (5.13.7.100, 224.8.6.0), RP 5.5.5.5 (5.13.7.100, 224.8.7.0), RP 5.5.5.5 (5.13.7.100, 224.8.8.0), RP 5.5.5.5 (7.14.8.100, 224.9.5.0), RP 5.5.5.5 (7.14.8.100, 224.9.6.0), RP 5.5.5.5 (7.14.8.100, 224.9.7.0), RP 5.5.5.5
Variable definitions
The following table defines parameters for the show ip msdp show-all command.
Variable |
Value |
file WORD<1–99> |
Specifies the file name to save the display output. |
vrf WORD<0–16> |
Displays configuration information for a particular VRF. |
vrfids WORD<0–512> |
Displays configuration information for a particular VRF ID. |
